1986 Renault Trafic Failed emissions test
BLANCHE1
Engine Performance problem
1986 Renault Trafic 4 cyl Two Wheel Drive Automatic
Compression test showed
#1 125
#2 120
#3 120
#4 120
Engine emitting hydrocarbons
What would cause this
Feb 2, 2009 at 6:49 AM
RACEFAN966
  • 5,029 POSTS
Ok so your car is running to lean. Now this can be caused by a number of things so you need to determine what might be causing it. It could be a bad EGR valve or a vacuum leak or a carburator adjusted wrong or bad O2 sensor telling the car to lean out and so on. So do you have a digital multi meter? Is you car carb or injected? Get back to me and we can go from there.
Feb 2, 2009 at 7:47 AM
