2005 Renault Scenic My car beeps 3 times before starting, t
54,000 MILES • 4 CYL • FWD • MANUAL
SLESTER
I read another post here stating that it's the fluid levels, however the fluid levels are checked on start up and the beeps happen BEFORE the engine starts.
This has only just started, servicing is not due yet, and there are no messages on the consumer console on the computer.
Jul 3, 2009 at 8:24 PM
DAVE H
  • 13,383 POSTS
The ECM/PCM (computer)does a system check when the key is turned ON .. not on start up .. there are many different warning's on different renault models .. if the beeping is occuring before you turn the key then it could be a warning from the alarm system .. maybe it has been triggered at some stage and it is letting you know ? a diagnostic scan of the vehicles computer should let you know the cause !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_847.png
Jul 5, 2009 at 10:08 PM
