2004 Renault Scenic not starting
MITCHLARK
  • 2004 RENAULT SCENIC
Engine Mechanical problem
2004 Renault Scenic 6 cyl Manual 58000 miles
car sometimes doesnt start have had to jump start battery checked ok just had service fuel filter changed etc still occasionally will not start for no reason also sometimes feels a bit sluggis. Supposedly has full service history and not much has been replaced except couple of filters
Sunday, June 7th, 2009 AT 3:51 PM
DAVE H
  • 13,384 POSTS
When the car will not start is the battery flat or does it run down with trying to start? We need as much information as possible on the problem. Check for fuel and spark at cylinders when the vehicle will not start !
Monday, June 8th, 2009 AT 5:16 AM
SES40
Remove and clean the TDC sensor that should do the trick.
Monday, September 14th, 2009 AT 5:34 PM
