2003 Renault Scenic gear box
MICHAEL COLLARD
2003 Renault Scenic Front Wheel Drive Manual 73000 miles
renault megan scenic 2003 i need to get a gear box for my car as other is on its way out apparently i have to get the code of the gear box is this true if so do i look under the hood off the car or do ilook else where can you help as i havent got a clue
Jul 24, 2009 at 9:28 PM
DAVE H
  • 13,383 POSTS
the trans code will be stamped or on a lable attached to the transmission ... contact your local renault dealer with your VIN number and they will be able to tell you the type of trans fitted to your vehicle ... or look in the phone book for your nearest transmission repair centre .. they should be able to recondition your existing transmisssion ... much cheaper than locating and buying a new one ? hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_887.png
Jul 25, 2009 at 10:56 PM
