2003 Renault Scenic car wont idel
2003 RENAULT SCENIC
DINGODNO
Engine Mechanical problem
2003 Renault Scenic 4 cyl Two Wheel Drive Manual
hi i have a renault scenic on a 53 plate 1.6 16v which will start ok but wont idel , i have removed and cleaned the tdc sensor , but still the same ,
it all started when the battery went flat and i had to bump start it , the car ran ok untill i stopped the car and its when it started , can anyone help please
i have put a new battery on
thanks
Oct 27, 2010 at 10:35 AM
DAVE H
  • 13,384 POSTS
have the car scanned for fault codes .. check the alternator is working correctly
Oct 28, 2010 at 9:06 PM
DINGODNO
hi done a diagnostic told me the crankshaft senseor is the problem
so ive ordered new one will let you know how i get on
Oct 28, 2010 at 11:08 PM
DAVE H
  • 13,384 POSTS
Thanks for letting us know .. please let us know if this works so other members can see your final fix
Oct 29, 2010 at 8:05 PM
DINGODNO
hi all , i replaced cam shaft and crank shaft sensors and still wont idle on the senic , any more ideas , i plugged back in to dio and no faults are coming up .
i just dont know wots wrong with it
Nov 1, 2010 at 4:28 AM
DAVE H
  • 13,384 POSTS
check for vacuum line leaks
Nov 1, 2010 at 12:11 PM
DINGODNO
where are the vaccum line links please
Nov 1, 2010 at 11:58 PM
DAVE H
  • 13,384 POSTS
there are numerous vacuum lines to check .. your local library or autoparts store will supply a repair manual with diagrams inside
Nov 3, 2010 at 9:11 PM
