2002 Renault Scenic Very sluggish in all gears
DEANERIC
  • 2002 RENAULT SCENIC
  • 4 CYL
  • FWD
  • MANUAL
  • 80,000 MILES
Especially when pulling off, pedel has to be down to the floor but still very sluggish. Hill starts are a no no.
Not just on pull off, all the time, no none of the maintenance lights are on.
Thursday, March 5th, 2009 AT 3:49 AM
DAVE H
  • 13,384 POSTS
Hello. Thanks for the donation. Much appreciated
We will need a little more information before we can offer a diagnosis ! Is the engine management light showing? Is there no power at all time's or just pulling off. Does it feel like it's missing. This could be a clutch issue?
Thursday, March 5th, 2009 AT 6:21 AM
DEANERIC
Not just on pull off, all the time really. No engine management light is on. Don't think its the clutch only had it replaced about 4 months ago.
Thursday, March 5th, 2009 AT 11:12 AM
DAVE H
  • 13,384 POSTS
With no MIL on. We are shooting in the wind really. From your description I would be saying it's a clutch issue? But if you just had it replaced it SHOULD be OK. You could have the garage who repaired it check it for you ! It could also be a plug fault/plug lead/coil/coil pack. CKP (crankshaft position sensor) there are numerous sensors etc. . We could be just swapping parts for no reason. Have the clutch checked it should still be under warranty. Check you are getting a good blue spark on each plug. Which system of coil do you have (coil pack or coil on plug)? Check you are getting fuel to each cylinder. All these faults should be bringing on the engine management light?. But it could also be a fault on the cars computer?. Let me know waht you think and about the clutch?
Thursday, March 5th, 2009 AT 12:11 PM
