2001 Renault Scenic ticking/rattling when i rev the engine
62,000 MILES • 4 CYL • FWD • MANUAL
WEEJOHN
when i rev my engine ,just lightly ,i am getting a really fast rattling /ticking noise ,the harder i rev the faster it gets . this is only happening when i rev the engine,i have been in the engine bay to have a look and the noise is coming from around the alternator part of the engine but i cant pin point just where it is coming from ,my father inlaw had a listen and said he would not worry but to get the t/belt changed ,but typically when he heard it it was not doing it so loud. I have no idea what this could be and its driving me nuts ,and im scared to go far in it just in case something happens. P.S only when i rev /not when idling .THANKS VERY MUCH
Jan 2, 2010 at 2:48 PM
DAVE H
  • 13,383 POSTS
Check the alternator belt and tensioner are good !! .. I would also take your father in laws advice and have the timing belt and tensioner changed .. this could be the fault .. manufacturer recomended timing belt change is @60,000 miles ..yours is due and if this does break or strip teeth it will cause engine damage to valves/pistons ? Hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_938.png
Jan 3, 2010 at 12:06 AM
