2001 Renault Scenic Speedometer
72,000 MILES • 4 CYL • FWD • AUTOMATIC
WOMBATWILLIS
Recently the speedometer gave up. On the instrument cluster everything else works perfectly, i.e. tachometer, fuel gauge, temperature gauge, etc.
Any idea? Is it a common problem? Likely to be a fault in the cluster or at sensor end/drive from the gearbox (I'm not sure of the input to these things - mechanical conventional type or electrical).
Regards
MARK WILLIS
Feb 20, 2008 at 2:01 AM
DAVE H
  • 13,383 POSTS
replace the VSS (vehicle speed sensor) located on the gearbox !
Mar 19, 2009 at 8:06 AM
