2001 Renault Scenic Knocking sound
35,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBMAC
I am experiencing a continual knocking sound from the area of the rear right hand wheel. Nothing seems to be loose and the damping on the shock absorber seems fine. Any ideas what it might be?
Many thanks Rob.
Have since replaced shocks and problem sorted!
Jan 4, 2008 at 5:29 AM
DAVE H
  • 13,383 POSTS
check/replace the shock absorbers/springs
Mar 21, 2010 at 12:16 AM
  • 55,628 POSTS
I have seen the front CV axle go out and cause this issue. Does it do it more when you are in a turn, if so this is where I would look.
Dec 18, 2024 at 5:06 AM
