2001 Renault Scenic drive shaft
70,000 MILES • 6 CYL • FWD • MANUAL
VONNY
The splines on my drive shaft sheared off. It was replaced and now 3 months later the same thing has happened again. Any ideas or is this a design fault with the scenic megane?
Oct 29, 2008 at 12:00 PM
DAVE H
  • 13,383 POSTS
Have your mechanic check the splines that your drive shaft goes into ? if these are worn they could be the cause of the second shaft damage .. will check if this is a common faullt for you ?
Nov 7, 2008 at 1:20 PM
