2000 Renault Scenic tdc
MASH290482
Engine Performance problem
2000 Renault Scenic Front Wheel Drive Automatic 78000 miles
where would i find the tdc sensor
Aug 12, 2008 at 10:44 PM
JIMMYTHEBRIT
  • 30 POSTS
tdc sensor is normally located on the top of the gearbox. it will be mounted against the side of the engine block and mounted by two 10mm bolts. it will have a small wiring connector leading to it also, be careful when removing as it is fragile and can be easily broken if not careful!
Oct 8, 2008 at 3:39 AM
