1999 Renault Scenic Intermittent stalling
SHEILA STEEL
1999 Renault Scenic Front Wheel Drive Manual 201000 miles
My v reg scenic has a intermittent stalling problem when the clutch is depressed. It can run fine for a few days and then just stall when you depress the clutch. Was told this could be the fule fillter have changed this and is still the same.
Apr 26, 2010 at 8:25 AM
DAVE H
  • 13,383 POSTS
is the check engine light on ? .. start by removing and cleaning or replacing the crankshaft position sensor
Apr 26, 2010 at 7:39 PM
