1998 Renault Scenic engine noises
146,000 MILES • 4 CYL • 2WD • MANUAL
CHRISTINE1984
my renault megane scenic is making a noise it sounded like loose fan belt but it is not that. when you rev it it sounds like bearings in turbo is this common or is it something else
May 13, 2010 at 10:00 PM
  • 31,937 POSTS
Hi there,
We do not have a lot of info on these cars, but if you have an inter cooler for the turbo system, check that it is not leaking or that there is a leak in the induction system between the turbo and the engine.
mark (mhpautos)
May 14, 2010 at 12:45 AM
