1998 Renault Scenic Air-Fuel Mix
CHRIS1775
Engine Mechanical problem
1998 Renault Scenic 4 cyl Two Wheel Drive Manual
Can you tell me if the air mixture screw is situated underneath the air filter or is it on the carburettor? When I start it up there is a strong smell of petrol and when I go up hill it does the same, is this to do with the air fuel mix or is it something else? Thank you, Chirs
Nov 16, 2009 at 10:58 PM
DAVE H
  • 13,383 POSTS
air/fuel mixture is electronically controlled by the cars PCM (computer) and cannot be adjusted ..check/clean/replace the MAF sensor ..check for vacuum leaks .. check for fuel leaks !!
Nov 18, 2009 at 8:09 PM
