Renault Cold Start Stalls
RENAULT
RAY RAYCROFT
I have a 2.2 Renault fuel inj. engine in my small motor home. Engine will start as soon as I turn the key but only runs for 3 to 5 seconds and stalls. Will continue to do this each time I try starting. If by pumping the acc. fast enough I can get it to keep runining for one to two minutes at a hight RPM it will continue to run normal. If I shut it off and try again in half hour I have the same problem starting it again.
Sep 28, 2007 at 1:41 PM
  • 75,988 POSTS
Have the idle air control valve/speed controller-might want to take it out and clean it and see what happens. Not it-check the throttle position sensor voltages at closed/opened.
Sep 28, 2007 at 4:57 PM
Suggested Repair
Remove and clean the idle air control valve or idle speed controller. If that does not resolve the stall, check throttle position sensor voltages at closed and open throttle.
Conversation Summary
The owner of a small motor home with a 2.2 Renault fuel-injected engine says it starts immediately but stalls after 3 to 5 seconds. Rapid accelerator pumping can keep it running briefly at high RPM, after which it runs normally, but the problem returns after a short shutdown. The expert suggests cleaning the idle air control valve and, if needed, checking throttle position sensor voltages.
