2006 Other Renault Models INJECTOR FAULT
2006 RENAULT
ZIIK
Engine Mechanical problem
2006 Other Renault Models Two Wheel Drive Automatic 25000 miles
i have had a problem which is really getting to me .
1stly i have changed all coils and new spark plugs have been put in with the normal service.
My car has only done 25000 miles. i was driving home and the stop light came up and error message INJECTOR FAULT.
The car went into limp mode and i pulled up and turned it off, left it for 5 min and started it and was ok . just to put my mind at ease as i travel alot on motorway i decided to call AA out, bless they came after 3 hours and put diagnostic comp on and lo behold NO ERRORS, but for some strange reason the airbag light and now service light are on.
Apr 11, 2010 at 4:39 AM
DAVE H
  • 13,383 POSTS
A simple glitch on the electrical system could be the reason the lights have come on ... have the lights turned off (by diagnostic computer) and drive the vehicle to see if the lights return ..
Apr 12, 2010 at 8:59 PM
ZIIK
no the service light is still on i used injector cleaner and since then i have not had problem on the comp it did not bring anything up i was advised the injectors needed cleaning so i used the cleaner
Apr 13, 2010 at 3:35 AM
DAVE H
  • 13,383 POSTS
There is a way of turning off the service light .. the service light comes on at set intervals to remind you to service the vehicle .. I cannot remember the sequence for turning off the service reminder on this vehicle it has been so long since I did it (not sold in the USA) .. Most good repair garages will have the sequence for turning off the light .. it takes 2 minutes and pushing a couple of buttons so there should be a minimal (if any) charge !
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1121.png
Apr 13, 2010 at 5:07 PM
