2003 Other Renault Models Not starting
2003 RENAULT
80,000 MILES • 4 CYL • 2WD • MANUAL
MOTOXY
This is a renault master 1980cc . I know its a van but I am desperate for advice. My mechanic hasn't a clue.
It failed to start on the starter but would start immediatly on a tow. Continues to run during the day mostley. Has failed to start on a couple of occasions when working closer to home.
It has been on the computer and everything checks out.
i thought it was air in the system so i changed the fuel filter bowl/filter and all the fuel lines. Also put a non return into the line from the filter to the pump.
Worked for a few days but now not starting again.
Any ideas?
Can a battery turn an engine for a reasnoble length of time and still be worn out?
Jun 8, 2008 at 4:18 AM
DAVE H
  • 13,384 POSTS
yes replace the battery .. once running check the alternator is chargeing
Mar 20, 2010 at 11:52 PM
