1998 Other Renault Models fuel usage
1998 RENAULT
HBBHARRY
Engine Performance problem
1998 Other Renault Models 4 cyl Two Wheel Drive Manual master miles
van has engine recent rebuild and gearbox same, engine rebuilt as person befrore not change oil ans was like grease. now van starts ok drives too but when press excelerator lots white smoke and seems choke itself with too much deisel,when gets up top speed drives ok but if slow down on bend and try to pick up speed seems slow do so taks while to get back up, if keeep elcellerator pressed and slow down in neutrl and then reengage gear ,keeps power ok, hopinh can help me thank you
Oct 26, 2008 at 5:06 AM
TECHNOPRO
  • 45 POSTS
Hi, is the white smoke at start up? If the white smoke is present it means that the diesel is not burning properly and you may have issues with the glow plugs. Does it runs fine when engine is hot?
Has the pump and the injectors been checked and recalibrated?
Is the air cleaner element ok?
Let us know how you get on.
Cheers
Oct 27, 2008 at 10:32 PM
