1996 Other Renault Models engine misfire
1996 RENAULT
77,000 MILES • 4 CYL • FWD • MANUAL
RICHARD ANTHONY COWELL
I have a 1996 “N” Renault 5 1.4 injection.
The car performs okay until the engine gets warm then starts missing badly.
When you turn the engine back on it starts racing.
The warmer it gets the worse it performs
I’ve changed : plugs ; plug leads ; rotor arm ; distributor cap.
I then called in a diagnostic guy who told me to replace the engine sensor cable on the engine management side which I have done.
This made no difference what so ever.
He then told me to change the coil and control box which I have done
I’ve sprayed WD40 around inlet manifold
I’ve sprayed carb cleaner into carb
Can you please assist
Aug 11, 2008 at 7:03 PM
Could be a problem with vacuum leak/the idle speed controller/EGR and PCV valves if it has one, also have the fuel pressure checked-
Aug 11, 2008 at 7:22 PM
