i have a 2002 renault megane 1.9 dti and there is lots of smoke coming out of the exsuce pipe can you tell me the problem ? thanks
May 7, 2009 at 4:15 AM
DAVE H
✓Experienced Mechanic
There could be numerous reason's for this fault .. you need to have the vehicle checked by a repair center .. a common fault on renault model's is the turbo failing !!
hope this helps
