2006 Renault Megane replacing radiator
GAREEGAREE
Engine Cooling problem
2006 Renault Megane 4 cyl Front Wheel Drive Manual 26.000 miles
Hi, ran into a badger and have damaged my radiator, cople of things, 1) in your opinion can i replace myself (moderate diyer) 2) do i need to replace A/C radiator which i notice is on the front of main radiator and some fins look damaged?
Jun 4, 2009 at 5:09 AM
DAVE H
  • 13,383 POSTS
replacing the radiator is a fairly simple repair ... if you suspect both are damaged I would replace both at the same time !! your local library or autopart's store will be able to supply a repair manual with step by step instruction's and diagram's of the repair should you need it .. hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_765.png
Jun 4, 2009 at 10:47 PM
