2005 Renault Megane Weird noise when starting
2005 RENAULT MEGANE
FRISCO
Engine Mechanical problem
2005 Renault Megane Two Wheel Drive Automatic 28000 miles
Hi guys,
just a quick question. I'm the owner of Renault Megane II Dynamique, 1.6 petrol - Automatic version, year 2005. Everytime I start the engine I can hear rumbling, sounding the same as you start diesel engine. It lasts for few seconds and theneverything is ok. Sometimes I have to press the "start" button twice. The transmition bar is obviously in position "P". Isn't in because of low oil level in a gear box. The thing is, when I park it in a slope surface it doesn't do it.
Jul 24, 2008 at 1:13 AM
AD-EM82
hi i have the same problem on my 2002 1.6 16v.but i am having a miss fire now to and feeling loss of power. did you find out what the problem was. thanks Adam
[quote:9db8fc8554="Frisco"]Engine Mechanical problem
Hi guys,
just a quick question. I'm the owner of Renault Megane II Dynamique, 1.6 petrol - Automatic version, year 2005. Everytime I start the engine I can hear rumbling, sounding the same as you start diesel engine. It lasts for few seconds and theneverything is ok. Sometimes I have to press the "start" button twice. The transmition bar is obviously in position "P". Isn't in because of low oil level in a gear box. The thing is, when I park it in a slope surface it doesn't do it.[/quote:9db8fc8554]
Sep 14, 2008 at 1:13 AM
JIMMYTHEBRIT
  • 30 POSTS
is it at all like a grinding noise momentarily on start up? sometimes cuts out after making the noise? if so it could be one of the top engine pulleys. has been known to be a cause of this type of problem on the new 1.6litre engines.
Oct 8, 2008 at 12:59 PM
