2005 Renault Megane beeping
2005 RENAULT MEGANE
10,500 MILES • 4 CYL • 2WD • MANUAL
MACNAM
I'm getting a beeping noise when I start the car. no warning lights are on and its just had a service. driving no problem. the mechanic that serviced it dont mind it, as long as it does'nt beep when your driving.
Apr 24, 2009 at 6:11 AM
DAVE H
  • 13,384 POSTS
There could be numerous reasons for the beep ... you need to have the vehicle plugged into a diagnostic scanner (computer) to locate the cause !!! The cars computer is telling you there is a fault somewhere .. it could be door ajar switch/coolant sensor/battery low or numerous other sensors !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_578.png
Apr 25, 2009 at 11:51 PM
