2004 Renault Megane window regulator
40,000 MILES • 4 CYL • FWD • MANUAL
JFEIGHREY
hi..drivers window wont go up or down..when i press window button i can hear motor but only for a split second..do i need only regulator or do i also need regulator and motor..
Feb 27, 2010 at 12:32 AM
DAVE H
  • 13,383 POSTS
the cable in the motor could be jamming up, so you may need both .. best to remove inner door panel and check before buying parts !
Feb 28, 2010 at 12:30 AM
