Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Renault
Megane
Brakes
Rotor
Replace/Remove
2004 Renault Megane Rear brake disc replacement
2004 RENAULT MEGANE
43,000 MILES • 4 CYL • FWD • MANUAL
WHEELERDEALER
MEMBER
1 POST
Can you advise me on the procedure for correctly adjusting the rear wheel bearing which comes as part of the brake disc
Jun 26, 2008 at 10:03 PM
KHLOW2008
Experienced Mechanic
Hi wheelerdealer,
The bearing unit is to be torqued at 45 ft/lbs.
No adjustment necessary as the spindle is fixed length.
Jul 6, 2008 at 1:43 AM
Add image or video
Ask a new question
Engine won't start
Engine misfire
