2004 Renault Megane Keyless push-button door locking
24,000 MILES • 4 CYL • 2WD • AUTOMATIC
SURESHS
I have a 54 plate Megane Privilige with keyless entry/ignition. Doors can be locked by pressing button on door handles. However, both driver and rear door push buttons no longer work (gradual decline in operation).
How can I fix the fault and will the other doors also soon be affected?
Mar 31, 2009 at 11:35 PM
DAVE H
  • 13,383 POSTS
the renault range has been plagued with electrical wiring fault's .. I would be checking the wiring to the switches !!
Apr 1, 2009 at 1:40 PM
SURESHS
Does this require removing the door panels.
How do I access the door lock switches/wiring to check them out?
Apr 2, 2009 at 2:55 AM
DAVE H
  • 13,383 POSTS
You will have to remove the inner door panel and check all the electrical connectors are on securely and there is no breaks or rubbing of the wiring also use a voltmeter to check power and ground/earth !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_427.png
Apr 4, 2009 at 11:13 PM
