2004 Renault Megane engine coils
34,000 MILES • 4 CYL • 2WD • MANUAL
CNICH87767
i have been told that there are 4 coils in the engine on my car 1 and 2 coils have had to be replaced,now my car has had to go back to the garage to have no 3 coil replaced,can any one tell me why these coils seem to fail ,3in the 18 months i have had the car,and why do the coils fail,have i a problem with some thing else which just burn out the coils,
thanks
randy
Sep 7, 2009 at 3:26 AM
DAVE H
  • 13,383 POSTS
It is generally a better option to replace all 4 coils at the same time .. as they always break down in sequence .. when one fails the others are not far behind .. you do not have any other faults causing them to fail .. just wear and tear !!
Sep 7, 2009 at 9:14 PM
RENAULTFOURTH
Two points here. There was a particular series of these coils which had problems in the manufacture. You are correct, whilst most non Renault cars have just one coil with five thick cables running to the plugs - Renault immerses separate cigar shaped coils virtually into the engine block. It is amazing that they work so well situated where they are - Being literally fried! Whether your coils were part of this batch, the Renault garage should be able to tell from the vehcile registration. Secondly they do seem to fail like a dominoes - hence some garages replace the lot at one go, whilst other places (to save cash!) replace the faulty one only. Then, invariably the others fall too. Usually at a very unfortunate time. Symptoms:- Engine performance becomes erratic. Genuine Renault parts cost around £45 each, then the fitting - simple but a charge +VAT. Hence a bill for four is eye watering. Probe Distributors - on Internet (I've no connection - used then though previously.) Deliver in 24 hours at a massive saving. They used to give a three year warranty too. Warning - Whilst to replace these coils is simple, watch the line up. The small securing screws must be handled carefully. Easy to break these off, although the coil collapse should still hold onto the plug tops. Not sure whether the EMU then rests itself thereafter. Sadly Renault symbol warnings on the display, have a habit of requiring a special piece of kit to clear off these dashboard notices. Just bought another Megane though - Must be mad or can cope with the odd heart stoppings. SamWoe
https://images.2carpros.com/forum/automotive_pictures/436718_Megane__Preston_p4_1.jpg
Nov 18, 2009 at 5:18 PM
