COMPUTER RESET??
40,000 MILES • 4 CYL • 2WD • MANUAL
CROWBLIND
hi my battery went flat on my megane sport 225 2.0l i managed to start it via jump leads from another fully charged battery, but since then the esr light has been stuck on and the computer no longer functions when you press the right hand talk, any idea what this could be?
kind regards, Alex
Oct 20, 2008 at 8:39 AM
DAVE H
  • 13,383 POSTS
It sounds like you have a voltage surge or you connected the jumpers backwards. Start by checking the fuses and fusible links here is a guide to help you get started.
Cheers
Feb 15, 2009 at 11:00 PM
SID ARMFIELD
The computer tells me that my car needs servicing i.e. oil change, I had this done recently at my local garage for less than a quarter of the price the main agents wanted but they could not reset the computer. The flashing spanner symbol is beginning to get on my nerves is there any away I can stop this flashing.
Apr 3, 2019 at 5:27 AM (Merged)
GEORDIEMARK
Have a look at your speedo and you should see a little black stalk sticking out at the bottom towards the right.
Make sure you are seeing the 'service requried' or 'change oil soon' message by using the button on the end of the wiper stalk then press and hold the little black stalk on the speedo.
It might take a bit ot pressure to depress the stalk (mine did) and keep holding it down. Keep holding - you will first see the message flash and then (keep holding) it will reset.
Did this to mine yesterday and it resets both messages (i.e fresh service interval comes up) and it gets rid of that annoying flashing spanner.
PUSTINJAK88
i have problems with my indicator lamp SERV is always on and i need to reset computer. if any one know how i can do that please say!!
thank's
DAVE H
  • 13,383 POSTS
you need to have the vehicle plugged into a computer to have the cars ECU reset. Here is a video to show you how
https://youtu.be/ahK_eucFi-k
