1999 Renault Megane cant get on line to brake ecu!!
110,000 MILES • 4 CYL • 2WD • MANUAL
DANNY3864
i have on the dash "the abs the hand brake,and the stop lights" are all on.. the brakes still work.. just no abs.. the brakes still work but i have no abs.. i have had the so called "brake ecu" replaced less then a year ago at a large cost.. but when i looked at it.. it looks like it has just be wired.. any ideas wats up again!!
May 19, 2009 at 8:51 PM
DAVE H
  • 13,383 POSTS
You need to have the vehicle plugged into a diagnostic computer to locate the cause of the fault ... when the ECU pick's up a fault on the ABS then it cut's ABS function ...hence the no ABS ... have the vehicle diagnosed and repost for more information regarding repair !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_704.png
May 19, 2009 at 9:55 PM
DANNY3864
yea i had it put on already.. and could not get on to line to the ecu for the brakes..
May 20, 2009 at 1:20 AM
