Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Renault
Megane
Body
Antenna
2002 Renault Megane replace electric aerial
2002 RENAULT MEGANE
44,000 MILES • 4 CYL • 2WD • MANUAL
SLIEILE
MEMBER
1 POST
Hi How do I remove the aerial from the rear wing. Cannot remove the plastic to release the main aerial
Jan 31, 2010 at 5:04 AM
DAVE H
Experienced Mechanic
the arieal is bolted to the inside of the wing .. you need to undo bolt inside
Feb 6, 2010 at 8:46 PM
Add image or video
Ask a new question
Engine won't start
Engine misfire
