2002 Renault Megane knocking noise when starting the engine
48,000 MILES • 4 CYL • 2WD • MANUAL
AD-EM82
i am getting a knocking noise when starting the engine up on my megane. in then stops after a few seconds. the car stalls then shortley after. and dose so a few times. the is a slight knocking noise on tick over only. and miss firs badley at 1500 to 2000 revs. where they drop to about a 1000 the go up then down again. i changed the plugs but still the same. hope you can help thanks adam
Sep 14, 2008 at 1:06 AM
DAVE H
  • 13,383 POSTS
have the vehicle plugged into a diagnostic scanner .. is the engine management light showing on dash display ?
Feb 26, 2009 at 1:10 AM
