2002 Renault Megane Can someone identify this part????
55,000 MILES • 4 CYL • 2WD • MANUAL
REECET
When I turn the igintion on into the second postion to enable the electric to the car, a strange knocking noise is heard coming from the passenger side compartment.
The noise is like something is trying to turn but cant, it happens about 6 times but then stops, and does not happen when the car is turning over or moving.
I have narrowed the noise down to a part that comes off the heater blower. See enclosed photos.
If someone could identify what that part does, if it is a critical part of the system, and how to fix or stop it (which can be done by just disconnecting the clip).
Many Thanks
Reece[img:45085e9898]http://www.2carpros.com/forum/automotive_pictures/535570_Jane_Car_1_1.jpg[/img:45085e9898]
[img:45085e9898]http://www.2carpros.com/forum/automotive_pictures/535570_Jane_Car_2_1.jpg[/img:45085e9898]
[img:45085e9898]http://www.2carpros.com/forum/automotive_pictures/535570_Jane_Car_3_1.jpg[/img:45085e9898]
Jun 5, 2010 at 10:01 PM
2CARPRO JACK
  • 11,533 POSTS
Im not familiar with Renaults, but it looks/sounds like it is a blend door acuator.Older GM trucks had problems with them and they would do EXACTLY what you describe.The doors go to a set position when key is shut off, then when powered back up, it moves the door over, if the actuator is bad or if there is a problem with the blend door it will click/thump several times until the controller thinks it has moved it to the correct position.If you look closely there may be a part number on it, then you could Google it to see for sure
Jun 6, 2010 at 2:08 AM
