2001 Renault Megane Speedo sensor replacement
FINLAYJ
2001 Renault Megane
Need to replace sensor, believe fitted on gearbox but need to know how to access.
May 8, 2009 at 5:06 AM
DAVE H
  • 13,383 POSTS
The VSS (vehicle speed sensor) is located on the top of the gearbox and to replace is a simple screw out and screw back in the the new and reclip on wiring connector ... I do not have a diagram of the VSS .. your local library or autoparts store should be able to supply a repair manual with instructions and diagrams .. hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_680.png
May 8, 2009 at 10:33 PM
