2001 Renault Megane Speedo sensor replacement
2001 RENAULT MEGANE
FINLAYJ
2001 Renault Megane
Need to replace sensor, believe fitted on gearbox but need to know how to access.
May 8, 2009 at 5:06 AM
DAVE H
  • 13,384 POSTS
The VSS (vehicle speed sensor) is located on the top of the gearbox and to replace is a simple screw out and screw back in the the new and reclip on wiring connector ... I do not have a diagram of the VSS .. your local library or autoparts store should be able to supply a repair manual with instructions and diagrams .. hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_680.png
May 8, 2009 at 10:33 PM
