2001 Renault Megane How change the battery in renualt megan
2001 RENAULT MEGANE
AMJAD.ALTADMRI
Electrical problem
2001 Renault Megane Two Wheel Drive Manual
How could I remove the battery in renualt megane 2001 hatchback?
I've opened the bonnet and removed the plastic cover then what??
Mar 14, 2009 at 4:20 AM
DAVE H
  • 13,384 POSTS
Unclip the wiring harness down the side of the battery .. the harness that goes to the positive terminal .. you should be able to see the main positive terminal nut .. undo the nut and the whole plastic cover will come upwards and you can position it out of the way and remove the battery ... the wiring harness clip/holder to the chassis has to be undone !!!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_238.png
Mar 14, 2009 at 9:20 AM
