2001 Renault Megane Faulty rear doors
2001 RENAULT MEGANE
81,000 MILES • 4 CYL • 2WD • MANUAL
KAYZEE
Hi
Both my rear doors won't open anymore. It started so you could only open them from the inside but now they won't open at all. Do I have to, and can I, take the door panels off to sort it or is it something to do with the key and central locking.
Thanks
Kay
Mar 26, 2010 at 5:30 AM
DAVE H
  • 13,384 POSTS
You need to remove the rear inside door panels (it is not easy, but can be done with the doors closed) check the linkages are still good, check wiring, or replace the door actuators, they may be jammed in the deadlocked position !
Mar 27, 2010 at 9:58 PM
