2001 Renault Megane engine running on 3 cylinders
48,000 MILES • 4 CYL • FWD • MANUAL
BENTLEY1
could the problem be one of the coil packs,the engine is only lumpy on tickover,drives ok,but there is a smell of petrol,due to one cylinder not fireing correctly. I will know which pot it is when it stops raining,I will test by process of elimination.please tell me if my suspicions are correct.
Sep 9, 2008 at 6:17 AM
DAVE H
  • 13,383 POSTS
your suspicions are probably correct .. but replace all 4 coils together as they break down in sequence and you will have this problem again soon if you don't !
Feb 26, 2009 at 1:12 AM
