2001 Renault Megane 2001 renault megane
2001 RENAULT MEGANE
90,000 MILES • 4 CYL • FWD • MANUAL
MIKECHERYL
2001 renault megane 1.4 16v drives perfect but when i come to a stop problems with tick over and the whole engine wobbles its had new plugs injector cleaner new lambar sensor and i tryed one new coil in it and moved it along each of the plugs but no better is it true u cant change just one youvegot to change all four
thanks
m myers
Mar 11, 2009 at 4:39 AM
DAVE H
  • 13,384 POSTS
you can just change one .. but I recommend changeing all 4 together as the break down in sequence so if you change one .. then 2 days or 2 weeks later you will be changeing another then another etc. do this simple test ... start the vehicle let it sit ticking over .. go under bonnet and unplug the little wiring connector to #1 coil .. the vehicle should stall out (stop running) do this test for all 4 one at a time .. if the car stays running when one of them is unplugged thats the bad one !! hope this helps .. let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_192.png
Mar 11, 2009 at 2:49 PM
