2000 Renault Megane engine revs
68,000 MILES • 4 CYL • 2WD • MANUAL
NEILSAFC
i have the 2.0 megane monaco ide and my problem is when i get to about 4500-5000 rpm the car seems to pull back on power odd time orang light come on when driving car normally the car runs great all seems ok.i had a diagnostic check and showed 4 faults 2 unknown, one fault showed the lambda senser inavtive after the cat and the other fault was a fuel pressure fault any ideas on this as to which part i need or if its something else
Nov 4, 2009 at 7:09 PM
DAVE H
  • 13,383 POSTS
start by adding a good fuel addative to the tank to clean oult the fuel system !
Nov 7, 2009 at 8:23 PM
