1999 Renault Megane heater problem
52,500 MILES • 4 CYL • FWD • MANUAL
KEV08
hi i have a heater problem in my car can u tell me the correct procedure abou bleeding the water system,ther are 2 bleed nipples on rubber hoses ,can u help please?
Nov 2, 2008 at 12:19 AM
DAVE H
  • 13,383 POSTS
drain coolant ... remove both bleed screws .. top up coolant untill it starts to pour out of the lowest bleed screw .. insert bleed screw into hole and tighten .. continue filling coolant untill water pours from top bleed screw .. reinsert bleed screw and top off coolant to correct level !!
Feb 23, 2009 at 1:21 AM
