1999 Renault Megane heater not blowing
1999 RENAULT MEGANE
97,000 MILES • 4 CYL • 2WD • MANUAL
JON4475
the heater only blows on the forth setting 1,2,3 does not. there is warm air coming out,when you start the car it makes a knocking noise from the bulk head where the motor is the air con only works on number 4 setting any help with this problem would be very wellcome.
Sep 7, 2008 at 6:46 AM
DAVE H
  • 13,384 POSTS
check the blower motor switch and the resistor !
Feb 26, 2009 at 1:31 AM
