1999 Renault Megane Front windscreen washer fuse
1999 RENAULT MEGANE
132,000 MILES • 4 CYL • 2WD • MANUAL
IVOR CONAGHAN
Cannot find windscreenwasher fuse location. I know where the fuse box is and have seen the fuse map but there is nothing there for front washer fuse.
I cannot even locate the pump so could someone please help.
Vehicle is right hand drive
Oct 24, 2010 at 12:45 AM
DAVE H
  • 13,384 POSTS
the pump is located attached to the washer bottle .. trace back the tubing from bonnet to locate the bottle .. the fuse is probably used by other systems on the car .. check all fuses are good
Oct 27, 2010 at 9:30 PM
