1999 Renault Megane
125,000 MILES • V12 • FWD • MANUAL
DAMBUSTER1979
my engine light has come on and so has the stop light,when i turn the engine off the fan still runs and there is a slight burning smell.
what is wrong?
Aug 9, 2009 at 11:34 AM
  • 31,937 POSTS
Hi there,
I don't have a great deal of information on your car, but if you can get a scan done and report the fault code i will see what i can do for you.
mark (mhpautos)
Aug 9, 2009 at 6:17 PM
DAVE H
  • 13,383 POSTS
Also check the coolant level is correct ... is the vehicle overheating or getting excessively hot ?
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_916.png
Aug 10, 2009 at 9:10 PM
DAMBUSTER1979
the engine is defanately hotter than usual, i ran the engine for a while earlier and the engine light came on after 12 minutes, i popped the hood and the fan was still running and the burning smell was there, rather like concentrated exhaust fumes rather than an electrical burning..
Aug 10, 2009 at 10:54 PM
DAVE H
  • 13,383 POSTS
With engine cold, check the coolant level is correct ... As MHPAuto's stated earlier, you are going to have to have a diagnostic scan done on the vehicle to see what fault codes the cars computer is storing, without these codes you may be replacing parts unnecassarily ...I'm thinking, faulty thermostat or coolant temp sensor if the coolant level is good !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_917.png
Aug 11, 2009 at 8:53 PM
