1998 Renault Megane catalytic converter
1998 RENAULT MEGANE
NAZIR
Engine Mechanical problem
1998 Renault Megane Two Wheel Drive Manual
I have a Renault Megane Capriolet 1.6cc car, I wonder how to fit the catalytic converter. They say I should not use a paste as it can break away as it hardens, so is there any special thing I need to put, or something I should know?
Thank you for your time
Jun 15, 2010 at 9:55 PM
DAVE H
  • 13,384 POSTS
if you are fitting an aftermaket convertor, welding is your best option unless you buy a direct fit which is bolt on using gaskets/sealer
Jun 16, 2010 at 8:36 PM
