1997 Renault Megane door latch
ANGELSCRY
Interior problem
1997 Renault Megane Manual 100000 miles
the door latch on rear os door is stuck shut on a p reg megane 1.9 diesel i have can you give me points to try opening it up and where i might be able to get a diagram of the lock and is it an mot failure
Jul 31, 2008 at 10:38 PM
DAVE H
  • 13,383 POSTS
yes it is an mot failure .. everything fitted to the vehicle has to be working correctly .. you need to get the inner panel off the door .. not an easy task with it closed but it has to be off to reach the mechanism and open the door .. usaully it is just the connector bar that has popped out of it's holder !
Feb 26, 2009 at 2:03 AM
