1996 Renault Megane TRANSMISSION FLUSH
1996 RENAULT MEGANE
JAPOJI123
Transmission problem
1996 Renault Megane 4 cyl Two Wheel Drive Automatic 75000k miles
How do I flush the transmission in the car using a transmission fluid exchanger? The car does not have hoses going to radiator for cooling as it appears to hae its own bult-in cooling system, so is it possible to flush it using a machine?
Feb 18, 2010 at 12:37 PM
DAVE H
  • 13,384 POSTS
there are drain and refill plugs located on the side of the transmission .. could I ask why you feel you need to flush this transmission ? ..
Mar 3, 2010 at 8:10 PM
