1996 Renault Megane clock dash lights
1996 RENAULT MEGANE
11,574 MILES • 6 CYL • 2WD • MANUAL
JIMBOMAC 2008
i would like to know why my clock lights have gone out its only the rev counter speedo and all the other lights are fine i put new bulbs in all and still no lights on the clocks so i cant see the speed revs heater and fuel geuges at night
Sep 9, 2009 at 9:09 AM
DAVE H
  • 13,384 POSTS
check the fuse for the dash display .. then check the wiring, use a voltmetre to check you sre getting power and ground to the bulbs .. if you are the display needs repairing/replacing !
Sep 9, 2009 at 9:54 PM
JIMBOMAC 2008
thank you dave that helps alot i will check all wiring ;
jim
Sep 11, 2009 at 11:11 AM
DAVE H
  • 13,384 POSTS
no problem .. please let us know your final fix !!
Sep 12, 2009 at 10:56 PM
