1999 Renault Masters Sliding Door
KITTENSCHTEIN
Interior problem
1999 Renault Masters Manual
I have a problem with my Vans Sliding Door. When I close it, it won't shut properly and leaves a gap up the top that you can see from the inside. This also means water gets in and ruins my ply.....grrr
Will I need a new door? Or is there something I can do to fix it?
Thanks
May 10, 2010 at 6:21 PM
DAVE H
  • 13,383 POSTS
check for blockages in the track or damaged/bent/loose track runners
May 10, 2010 at 8:22 PM
KITTENSCHTEIN
Thanks for the tip, I have tried to get them as clean as possible, but maybe the door runner is bent.....? I will investigate and let you know the result : )
Thank you
Kitty x
May 13, 2010 at 6:11 PM
DAVE H
  • 13,383 POSTS
No problem .. please let us know your final fix
May 21, 2010 at 9:31 PM
