2004 Renault Laguna Engine Vibration and Whirring/whinning
70,000 MILES • 6 CYL • FWD • MANUAL
RAY GRANT
Hi again!
Can you please assist and confirm if you know the answer?
When travelling at the above subject speed i here a whinning and whirring noise around the speed at 50/60,the my car have beeen to renault cardiff for a diognostic check and its 100%, i am not loosing power and the car is running well,but the whinning is still there,however, i have had a new clutch fitted 27-03-2010,but still have the noise.
Do you know the answer please.
Krgds
Ray
Mar 28, 2010 at 4:06 AM
DAVE H
  • 13,383 POSTS
I would have the technicians test drive the vehicle to hear the noise .. it may be inside the gearbox at higher gears (worn gears) if the noise is only at 50/60 MPH .. these types of fault will not show up on a diagnostic scan !
Mar 28, 2010 at 8:46 PM
