2003 Renault Laguna EGR Valve?
RED09121989
Engine Performance problem
2003 Renault Laguna Front Wheel Drive Manual 96000 miles
Hi, about a month ago the turbo went on our laguna. We had the turbo reconditioned and re-fitted, however there seems to be no power. The turbo is spinning but the rev counter will not go above 3000. We took it to the garage and they suggested that the egr valve could be the problem. And when we investigated into the engine, it seems like the guy who re-fitted the turbo had not flushed out the engine to get rid of the old oil so oil was everywhere, so someone also suggested that oil may be in the intercooler which could also be affecting the performance. Please could you come up with a suggestion?
Much appreciated
Nov 11, 2008 at 8:14 AM
KHLOW2008
  • 41,812 POSTS
Hi red09121989,
Thank you for the donation.
When there is sign of oil all over the engine, it could be caused by high blowby pressure and this is normally associated with a clogged exhaust system.
Originally the turbo failed which could be due to the clogged exhaust, so I would suggest checking the catalytic converter for clogging.
Nov 12, 2008 at 3:33 AM
